BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
Tried removing air box today, removed all screws and hoses, was loose but did not to come out,corner of box would not clear rad hose. Does air box come out without removing rad hose or coolant resevoir?
MART1030
- Mar 10, 2012
Yes Whit a litle bit on force you need get them out off the way
Takes some finagling and then you have to watch the lower clip nuts when going back in as they like to migrate out of position.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
I did take off the two screws at the front holding the rad so you can swing the rad to either side.
Birkebeiner
Birkebeiner
BTbt
- Apr 11, 2005
- Kettleby, Ontario
That might help, having to force too much not a good idea to me, plus still needs to back in
Chris Purvis
- Jan 8, 2017
- Markstay
- 2016 SR Viper LTX SE
Having issues with airbox as well. I'm removing because the intake is covered in oil underneath box. Any fixes to the oil going into the airbox?
Have to have oil level correct. It's a timed procedure and it does matter if warm or cold. Should be procedure in FAQ. Your manual also.Having issues with airbox as well. I'm removing because the intake is covered in oil underneath box. Any fixes to the oil going into the airbox?
Here
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Although it can be done without removing coolant bottle, getting that loose gives you room to pull the air box out easily. Only two screws holding coolant bottle in so it's super easy to get it out of the way.
