bleedinblue
I have a innovate motorsports air/fuel mixture gauge for my apex mpi supercharger and it is blinking E 4. Does any one know what it means?
badluck
- Feb 6, 2006
- Ballston Spa, New York
- 06 Apex RTX S/C
09 Nytro RTX
Error 4- Pump cell circuit open
Cause-1. Damaged cable or DIN
connector not fully seated
2. Sensor heater calibration
incorrect
Fix 1. Verify DIN connector is fully
seated into unit. Repair/replace
cable.
2. Perform complete heater
calibration (not just free air
calibration). See section 4.6
incorrect
cable.
Yamanator
- May 5, 2003
- Oxford,Mi
- 2017 Sidewinder LTX LE
Also, if you need a new sending unit for the 02 sensor, DO NOT GO THROUGH MPI. I had to replace my sensor and MPI wanted double what I got it for from AutoZone.
What is the Auto Zone part #?
Yamanator
- May 5, 2003
- Oxford,Mi
rxwarrior said:What is the Auto Zone part #?
I am not sure, I took my part in and they matched it up, $50.00
bleedinblue
Thanks for info. I will check connections because i did have things apart the other day tightening supercharger belt.
SPEED
Bosch # for unit is17014 NGK does make a replacement. I do not have the crossover # but I,m sure the auto zone can cross reference for you
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
The sensor is a Bosch LSU4.2 5-wire.
Innovate Motorsports $79.00
http://www.innovatemotorsports.com/xcar ... 251&page=1
DIYAutotune $79.00
http://www.diyautotune.com/catalog/bosc ... p-125.html
Or you can get it from any VW automobile dealership.
DIYAutotune $79.00
Yamanator
- May 5, 2003
- Oxford,Mi
rxrider said:The sensor is a Bosch LSU4.2 5-wire.
DIYAutotune $79.00
This is right, I bought the lsu42-5wire at AutoZone and I am sure it was right around $51.00 total.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Sounds right, the general autoshops are usually cheaper than the tuning shops
venom
where can i get one in canada?or one that will stand up to race fuel.mine craped out after 2 days running 50/50 mix.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
venom - are you running leaded race fuel? Sensors life span are wastly shortened if ran on leaded fuels.
In Canada you could get the sensor from FJO Racing Products in Winnipeg. Their partno for the Bosch sensor is SO20004, price in USD is $70.75
http://www.fjoracing.com/pricelist.php
venom
rxrider i'm running vp c 111 which is leaded.rode a all last year on pump gas and not a prob.this year 3 days with 50/50 mix and it's toast.
THANKS
anybody try the ntk sensors?on fjo's web site it tells u that the bocsh sensor is not for use with leaded fuel.not much point in buying a bosch.
THANKS
THANKS
THANKS
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
I had error 4 , I was told that I had a bad ground , by Philipe' at Innovate ,
He said my ground had to be on the engine , I added a ground from the engine to the chassis ,
same problem , then he said the gauge was seeing cranking voltage ,intermittent voltage during crank, the gauge is seeing it, going into calibration mode , I changed mine over to voltage after start and , all ok ***
lakercr
Tech Advisor
venom said:rxrider i'm running vp c 111 which is leaded.rode a all last year on pump gas and not a prob.this year 3 days with 50/50 mix and it's toast.
THANKS
THANKS
Myself and lots of our customers are running the NTK's with race fuel (BPE is a FJO distributor) They work very well. I don't think the FJO NTK is plug and play for your gauge. I'll check with FJO in the morning and confirm for you.
