air pressure fox float evols
rayone02
adrian, mi
2012 Apex 2012 nytro xtx 2006 attak
How many times you recheck Air pressure during the season on fox.floats?
I'm checking mine every ride until the seals set in better after my rebuild and conversion to the evol's. Down about 10 psi on one side, 2-3lb. on the other. Expansion canister pressure seems to be holding fine. Don't think there is much I can do, but put some miles on the shocks to wear in new seals. 250 miles and counting!
I run rebuilt floats from Hygear Suspension. I check pressure about twice a year Even after summer storage still at 70 lbs,
07 RTX
