TurboJamie
Question why run the hose on the outside and risk being crushed by stepping on it or who knows what else? Can the hose not be run similar to the ES shocks on apex's of past inside the tunnel?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Super Sled said:Boy that looks awesome, Mr. Ulmer!!!!!!!!! How hard is the install? Any idea of additional cost on top of buying the new mega Float>
Thx!
Mike
Install is pretty straight forward, it does take some time to route everything and get it all mounted.
TurboJamie said:Question why run the hose on the outside and risk being crushed by stepping on it or who knows what else? Can the hose not be run similar to the ES shocks on apex's of past inside the tunnel?
Because I believe there is a higher risk with debris and ice chunks on the inside of the tunnel than there is with the possibility of damage on the outside of the tunnel. The tube actually sits below all the raised ridges on tunnel so I do not believe it will have any damage, only snow and miles will tell!
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
turbojamie,
Please take the time to update your location in your profile, thanks!
smilened
The routing of the airline is the same that I ran on my Rage with an Airwave suspension. I have had zero problems with it. It is a very sweet setup!!!!
Dasher
Alan,
Is their any risk of condensation being produced by the compressor and resulting in freezing in the lines?
- Apr 17, 2003
- Menno, SD
- Menno, SD
I do not for see any risk of condensation at this time. This is a very similar setup to what is used on the M-20 Airwave suspensions as well.
- 9K
