Air Shock Storage
jat59
Rockford IL
Is it better to let the air out of the shocks (some or all the air) for summer storage or just leave it where you have them set? Tried doing a search but came up empty on the subject.
I bet you're coming up empty 'cause no one has ever questioned this. I havn't.
If you're really interested, I do nothing with the air in my floats.
Can't say if I'm right or wrong. But that's what I do and I've never heard any different.
My first year I took most of the pressure out. I left 10psi so that nothing inside was sticking to itself. And took all the weight off the front and back shocks. Then last year I did nothing to the front stocks except for take the weight off.
I also don't know what is the right thing to do.
Super Sled said:
I treat them the same as my coil over shocks.
Me too, mostly. I leave a little pressure on them, and soak them down pretty good with WD-40, especially in the area of the shaft and seal.
