Vmax540
- Jul 25, 2005
- Clarion Pa.
- www.vintagevmax.com
A sled (insert name) that is between the Phazer and Vector/Rage.
-4 stroke, 3cyl., 6-700cc, 100-120Hp.
-Phazer like chassis/suspension
-Wind protection hopefully a fairing and not the ughly.... Fourwheeler style windshield/headlight !
-128 to 136" track.
-A Real storage compartment.
-A soft seat.
- Sorry guys but, it could be a front dump exhaust don't want to deal with the icing/heat/weight/space taking issues of a rear exhaust.
-Electronic reverse ?
-Max. of 500lbs without Fuel.
-7-8500$
-128 to 136" track.
-A soft seat.
-7-8500$
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Unless Yamaha is magic 4 strokes can't run backwards like a 2-smoke can.......Vmax540 said:A sled (insert name) that is between the Phazer and Vector/Rage.
LazyBastard
Even on a 2-smoke, I wouldn't go near a backwards spinning reverse. Too much extra junk required for the secondary clutch to work, and UNRELIABLE!!!
And WTH is a "fourwheeler style windshield/headlight"? Last I checked, fourwheelers DONT HAVE WINDSHIELDS (unless you add it yourself), and have headlights mounted at the front of the fenders.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
I disagree, Doo has been doing it for what 6 years now? Then when Polaris sued them over the rear skid issue Doo gave them the rights for it in their settlement.LazyBastard said:Even on a 2-smoke, I wouldn't go near a backwards spinning reverse. Too much extra junk required for the secondary clutch to work, and UNRELIABLE!!!
LazyBastard
A doo engine isn't even reliable in FORWARD. Most times I see a doo trying to switch into backwards, it stalls in the process.
reverse
All the Doo's and Polaris's stall out and then restart everytime they go from forward to reverse and back to forward. Thats they way it works.
LazyBastard
You're not listening. I mean stall as in DON'T RUN UNTIL YOU YANK THE CORD.
reverse
OK I understand.
OK I understand.
7 skulls
I filled out a yamaha survey a little while ago that listed an 80-110hp class of snowmobile so you know its coming... just not in 08. The current race sled is what we'll get since there will only be one new model every year. As for the sled in between the phazer and the vector, I'll bet this is what it looks like...
MadMax
1. A 120 for the kids that looks like a big yammie.
2 A new lighter 120/130 hp sled.
3Better wheels.
4 Quiet tracks.
5Built in GPS / outside temp gage.
6 Even better skis.
I know, dream on.. MM.
3Better wheels.
4 Quiet tracks.
6 Even better skis.
Vmax540
- Jul 25, 2005
- Clarion Pa.
When I said electronic reverse I should have said Push Button not a manual lever.......
studdog
Good thread VMAX540. I want a nice clean design not a dirtbike look like phaser. Quiet power. No rear exhaust. Fuel injection. Decent mirrors. Luugage rack and fully articulating backrest. Hand warmers that work. An accessable engine compartment. A skid design that doesn't eat hyfax. I could go on and on!
sxmatt
I would like to see a Phazer type sled with a fuel injected vector motor with a true 130 hp, a 136 inch skid which had a dual shock setup and torsion springs that had a smooth ride like the mono but could have the adjustment to ride it hard in the rough weekend moguls, a set of easy turning skis that had dual keels and were very aggressive, good wind protection for body and hands, both height adjustable and articulating riser block, HOT handwarmers, and weigh in at a respectable 510-520 dry.
Matt
Matt
Vmax540
- Jul 25, 2005
- Clarion Pa.
Amen.......... !
studdog said:Good thread VMAX540. I want a nice clean design not a dirtbike look like phaser. Quiet power. No rear exhaust. Fuel injection. Decent mirrors. Luugage rack and fully articulating backrest. Hand warmers that work. An accessable engine compartment. A skid design that doesn't eat hyfax. I could go on and on!
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Id like to see the 130hp vector motor in the apex chasis, with good wheels and a new skis design!
- 13K
