Sled Dog
Where does one find these and does anyone have a part number or dimensions?
Sled Dog
I did some digging and it looks like no one actually posted the right kind of allen head screw to get to replace the stock ones. It looks like Stainless steel 12 m4 70 is the ones to get can anyone confirm this?
maxdlx
I used to get them at lowes for the old mikinu carbs, but don't know if these are the same, but those where 4 mm by what ever length you needed. maxdlx
Sled Dog
Here is a link to the bolt needed for the float bowls. Yamaha in Yorkton wants $9.63 cents per screw. I dont think so. Here is the link to fastenal to the bolt I beleive is the one we need.
http://www.fastenal.com/web/products/de ... ku=1139525
maxdlx
100 would be enough for 6 sleds, to bad the shipping would kill a guy
Sled Dog
Here is the stainless steel link as well. This should be stuck in the tech pages as an add on to the carburater jetting and cleaning sections.
http://www.fastenal.com/web/products/de ... 0012A20000
RXMax
I believe the 12MM is too long for some of the spots on the carbs. 2 can be 12mm, but the other 2 have be shorter. The local autoparts store only had 12mm or 6mm I am thinking an 8mm or 10mm would be better.
Sled Dog
The 16 float bowl screws I took out on both sledsl were all the same size and length.
RXMax
I know.. but 12mm you were speaking of will be too long at least they are for 2 out of the 4 holes on each carb on my 03... stock are 10mm I do believe. Stock screws from yamaha are $.65 each .. Your dealer has quite the mark up...
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I replaced the screws on my wifes sled with some #2 stainless metric screws from my local mom-n-pop hardware for .23 cents apiece, the head was a little larger but they worked just fine.
Sled Dog
I will measure one out and find the exact one needed.
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
4mm X 0.7pitch X 10mm long
I put the hex head in stainless. Got them at Ace Hardware.
Sled Dog
SnoWarrior said:4mm X 0.7pitch X 10mm long
Thanks I was very surprised to see this info was not readily available for anyone who wanted to change them.
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
Sled Dog said:SnoWarrior said:4mm X 0.7pitch X 10mm long
I posted this info in october in the mtn segment. http://www.ty4stroke.com/viewtopic.php? ... highlight=
Jim
Sled Dog
True but thats really not readily available or easy to find in a search. I was searching for float bowl screw replacement and it did not come up. I am thinking more as in the tech pages so it is easy to find.
