Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Hmmm.... I'm assuming you then cover that barb on the filter elbow? Wouldn't the oil just come out of that filter eventually. Hey, just checking....lolSmall specre universal filter from o'rileys with a barb fitting is what i use on my sleds.
Doc Harley
- Oct 17, 2016
- Here & there
Side note; I put a call in to Turbo Dynamics just to verify my thoughts. They no longer sell the Cai tunes. You just slap an open filter on and go.
My initial thoughts on the TD tunes were they are a tad bit rich from the smell of things.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Bought about 3 feet of hose. Removed old hose on top of valve cover installed new hose on valve cover and ran down next to my oil tank vent near right foot. Zero oil going into intake and no oil vapors going onto clutch if left open.B4 I button her up. What's the solution to prevent oil at valve cover from entering air intake?
Doc Harley
- Oct 17, 2016
- Here & there
Yep, probably for the best. We need a vented catch can.Bought about 3 feet of hose. Removed old hose on top of valve cover installed new hose on valve cover and ran down next to my oil tank vent near right foot. Zero oil going into intake and no oil vapors going onto clutch if left open.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
No catch can ever!
Fords4life
- Dec 7, 2021
- South Dakota
Never have had any oil come out the spectre filter, its mounted up along side the fuel return hose.Hmmm.... I'm assuming you then cover that barb on the filter elbow? Wouldn't the oil just come out of that filter eventually. Hey, just checking....lol
Doc Harley
- Oct 17, 2016
- Here & there
For now I plugged it into filter elbow. Until I can get a l good look at what you did!Never have had any oil come out the spectre filter, its mounted up along side the fuel return hose.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
There is no oil that comes out of the valve cover vent hose. The vent hose from the valve cover goes right into the intake tube. Why are people overthinking this?
Sounds like a bunch of Ski-Doo dudes talking about catch cans, filters and stuff. There is a place to attach the vent hose to the intake, put it there....
Turboflash
- Mar 18, 2019
- Southern MN
If you have oil vapor, oil mist, or smoke fumes, or anything coming out of that hose, you need to rebuild your engine. You must have bad rings or piston problems causing excessive blowby.
Doc Harley
- Oct 17, 2016
- Here & there
Mine has oil coming out of it...ughThere is no oil that comes out of the valve cover vent hose. The vent hose from the valve cover goes right into the intake tube. Why are people overthinking this?
Ehw....what to do now? Try a leak down test? I would honestly try to hobble her thru this season, if that's the case.If you have oil vapor, oil mist, or smoke fumes, or anything coming out of that hose, you need to rebuild your engine. You must have bad rings or piston problems causing excessive blowby.
Doc Harley
- Oct 17, 2016
- Here & there
Pics from '22 had one funny looking plug & did a compression test. All three cylinders were 160psi using an AutoZone gauge. No oil on plugs.
Yes, cheap gauges can cause faulty readings. But the point would be, all equal. You think all cylinders would be down, evenly??
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Do a leak down test
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, know NYTurbo it's been doing it since day one. Others say "you'll get something out of there" so, idk....Do a leak down test
I'll have to borrow one from AutoZone, I'm not sure if I'd even trust those results.
What a joke ...
Doc Harley
- Oct 17, 2016
- Here & there
Well..... A lot of guys get blow by through this tube. That doesn't make it right. Someone explained that if your oils too high that you'll get a little bit more than normal. And I run my oil high. Who knows. But as of now I'm not too worried.
Same applies to my Harley. If I don't run it a half quart low, s*** spraying everywhere.
Fords4life
- Dec 7, 2021
- South Dakota
Jt dont frett it much, with the hose hooked to intake track you will have oil in filter area because of vacume pull on rocker cover, with hose not hooked to intake track and a seperate filter on that hose no vacume pull no oil there.
- 8K
