Another RB3 Question
Rx1M5
Calgary Alberta
Can the RB3 be used to control fuel supply when running a nitrous shot. Does it have an input that could be tied to the Nitrous button that would allow you to swap maps instantly or something in order to add fuel for the nitrous shot. Am I off base here?
Rx1M5
Yes it can switch maps instantly at any rpm by grounding one wire in the harness.
The second fuel map is also tied to a second 3d timing map so you can pull timming and add fuel when you hit the happy button.
OK next question. Are the Nytro injectors capable of suppling enough extra fuel or would I need some kind of secondary injectors. Im only talking about a 45 horse shot give or take. On the Boss Noss system I used to have it had the fuel dumps which added the extra fuel to the casrbs but I have no idea how much they actually added.
Rx1M5
The stock Nytro injectors will provide enough fuel to, well over 200hp
