soul_hammer
I am stretching my Phazer to a 136 for this winter so I thought I would document it.
Here is the track I will be using Its a 136x16x1.25 off a renegade.
Here is the cutting method I used.
Here is the cutting in progress after we got the technique down it went fairly easy.
Lat but not least here is the result.
It is now a 136x14.3x1.25.
Now to pick some rail extensions.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Great pics. It looked like it left you a really nice cut edge. You are going to feel like your sled has 30 more HP running that track.
G.B.
G.B.
soul_hammer
Thanks Gone, I just hope I can float a little better, the added traction will just be a big bonus. Lol
Yes it left a really clean edge, better than I thought it would even.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
So after cutting & then some use, what keeps the edges from fraying like some tracks I've seen do?
Do you melt/burn 'em or something?
My Freeride has some of the fibers showing in a couple spots...
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
My brand new Freeride had a few threads showing when I took it out of the box. I wouldn't worry about it.
Yes. Just burn them off if wanted.
RoicIND
track
X2
Use a small propane torch to singe the edges
cannondale27 said:Yes. Just burn them off if wanted.
X2
soul_hammer
My stock one has frayed at the edges also but not to the extent that I am worried about it. the process of cutting melted the edges quite a bit and it doesn't appear as though it is any more prone to fraying than a new track I did plan on putting some epoxy on the fiberglass rods just as a precaution.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Do you have to change out your drivers up front, or does that Gade track have the same pitch? I was thinking all Doo's had a different pitch.
Nice work!
Nice work!
soul_hammer
Its off an 06 so they have the same driver pitch. 06 back have the 2.52 drivers like the Phazer
Thanks.
Thanks.
soul_hammer
Well the extensions are on the way so hopefully I will be done in the next few weeks. pictures will be posted of all updates.
Awesome!
soul_hammer
I pulled the bumper and flap for extension today, man she looks weird without it.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Nice wrap!
G.B.
G.B.
soul_hammer
Trimmed up and finished riviting the extension today and I decided to wrap the top of the tunnel also while I was at it.
Then I plastidipped part of the bumper to see what it would look like and I like it. The whole thing will be done when I find some tube to use to weld it up.
- 47K
