Antifreeze Consumption
anitfreeze use
Make sure to check between carbs for potential leaks. Have to remove air filter to see. When I did mine I could see antifreeze drippping out one of the small aluminum lines that connect the carbs together. Point, you won't see it unless you remove airbox. Dealer said this is a common fault and their fix is to put 2 o-rings in at juncture of each aluminum antifreeze feed line and the carbs they connect to.
Carb leaks?
Longshot is right , they did update the carb assemblies this year.. The aluminum tube is now made to accept two o-rings, so it is not just adding o-rings. Don't attempt to do this unless you know what you are doing because there are alot of little parts that come apart when you dissassemble these carbs. The little springson the throttle assemblies are a bitch to put back.
