antifreeze
martin63092
Kapuskasing, Ontario, Canada
i just tip my sled on the right hand side and antifreeze was leaking all over the place, i guess this is just antifreeze coming out of the overflow?
is this normal? should i just fill up antifreeze then go or should i do something else to it?
If the level dropped bellow the essaying you might need to bleed the system to get any air that might have gotten sucked in out.
