jp87
- Nov 5, 2011
I hear yamaha uses a wet clutch starter system. Has anyone had problems with there starters not working because they didn't run yamalube or oil that didn't meet jaso MA specs.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You will be fine. The starter is not a wet clutch system, it is a one way locking pin design. The motor oil will not hurt it.
