monker
I have an 04 silverado that I have been towing with for some time. My right rear trailer brake light has stopped working for some reason now. When tested with at 12v source the trailer is fine. Using a meter, there is no 12v coming from the 7 pin connector on the truck. As far as I can tell, fuses look ok, but I didn't see one labeled specifically for trailer brake lights.
Any sugestions?
Any sugestions?
Boomer
Hey Monker, Hows it going?
Have you checked under the trailer for all the wires. when I went to get my trailer ready this year I had the same problem only with a few more lights. Turns out I have a woodchuck that seemed to think the exposed wires under the trailer make a pretty good snack. Had to rerun some wires and do repairs on others. Basically just replaced and fortified the wires so it would be harder for them to get to and weather sealed everything.
Good luck and hope to see you this year.
Boomer (Dale)
Boomer (Dale)
monker
yeah, all the trailer lights work when I use a different 12v source. The problem is on the pickup somewhere. Weird thing is the turn signal uses the same wire and works fine.
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
I had the same problem with my Golf last week. The module that gets plugged in to the wiring harness of the car had trouble in it. Replace the module and all is good. Not sure if your truck has a similar setup
jim-bob
under the hood theres a box with additional fuses/ its probably one of those / red colored I believe / later
monker
Well, I went through every fuse with a meter and all came up good. I guess is could be some module under there. Looks like a trip to the dealer.
WANN4STROKE
- Feb 26, 2007
- Anchorage, Ak.
- 2009 Viking
2006 ApxMtn-sold
2001 MtnMax-sold
1998 VMAX 500-totalled
Try replacing the wire harness. It should be a plug in type. A clip on each side and put the new one in.
sparks49
My father-in-law's truck had the same problem and we found it to be a fuse. Check your manual and see if you can track it down, the trailer harness uses a different fuse than the regular lights in the truck.
Good Luck
Good Luck
Tom-RX1
Have had the same problem a few times the fuse is under the hood . spent about 3 hrs looking for it the first time it happened .
Tom-RX1
Tom-RX1
jim-bob said:under the hood theres a box with additional fuses/ its probably one of those / red colored I believe / later
I had a similar problem with my '07 Tahoe when I installed ski guides on my trailer and accidentally ran a screw through one of the trailer wires. In my truck, there is a fuse box under the hood on the driver's side that uses mini-fuses. I cooked two of them. Once I discovered/corrected the problem with the trailer and replaced the fuses, all was well.
jim-bob
are you getting the hint/ about UNDER the hood/ good luck/ Later
Gilly
there are also trailer fuses in the fuse panel left side of dash when you open the drivers door . I work at a GM dealership.
- 26K
