Anybody have Lincoln's dropdown bracket fix??
Okay Thrusted V, I will go for it!!! Although I won't have time to do it for a while since my time is extremely limited, but I will the first chance I get.
Drilled the holes, moved the bolts and just came back from a test run. The sled feels alot lighter in the front I can't believe it. Glad I tried it. :Rockon: I'll be going a nice ride tomorrow to really try it out.
Hey Linc
Is this mod done on my sled? The white RX that you built?
LFM
No,your's has a Holz suspension,it doesn't need it,You've got got the the much more expensive fix of the same problem.
I met the owner of Holz last weekend in the Callaghan parking lot, He had a Polaris 440 race chasis with a 660 in it and every light weight Holz part around. He long tracked it and it looks killer. He also had a couple other cool sleds all Holz 'ed out. Nice guy...He said he would re-coat my A-arms for free as the coating was pealing off.
Lincoln, What is the distance you recommend drilling the hole above the stock hole? I know too much and my under tunnel exhaust will take a beating, too little and I won't get the benefits.
On the dropdown bracket I drilled the hole the same distance apart from the other two holes. Same goes for the front bracket.
The only thing you should look out for is the side of the track rubbing on your drop down bracket bolt. Mine rubbed since the track dropped down and I burned off 4 lugs.
kool yeah seen those....but was just wondering if anyone has the finished look of the sled...
like how does it look from the side view...how low....
and also all put together meaning bolted all up to the suspension...
thx
Stiff
