ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Okay Thrusted V, I will go for it!!! Although I won't have time to do it for a while since my time is extremely limited, but I will the first chance I get.
Thrusted Vector
It takes about an hour in the shop.So you shouldn't have too much trouble.Let me know how it works out.
Drilled the holes, moved the bolts and just came back from a test run. The sled feels alot lighter in the front I can't believe it. Glad I tried it.
I'll be going a nice ride tomorrow to really try it out.
I'll be going a nice ride tomorrow to really try it out.LFM
Hey Linc
Is this mod done on my sled? The white RX that you built?
LFM
LFM
Thrusted Vector
No,your's has a Holz suspension,it doesn't need it,You've got got the the much more expensive fix of the same problem.
LFM
I met the owner of Holz last weekend in the Callaghan parking lot, He had a Polaris 440 race chasis with a 660 in it and every light weight Holz part around. He long tracked it and it looks killer. He also had a couple other cool sleds all Holz 'ed out. Nice guy...He said he would re-coat my A-arms for free as the coating was pealing off.
Thrusted Vector
Ya, Mark's a pretty stand up guy.
YaMon
Lincoln, What is the distance you recommend drilling the hole above the stock hole? I know too much and my under tunnel exhaust will take a beating, too little and I won't get the benefits.
AaronBND
Holy crap this post is old!
Aaron
Aaron
Thatspec
Old yeah but still the best (and cheapest) thing you can do to the stock rear suspension.....
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
On the dropdown bracket I drilled the hole the same distance apart from the other two holes. Same goes for the front bracket.
The only thing you should look out for is the side of the track rubbing on your drop down bracket bolt. Mine rubbed since the track dropped down and I burned off 4 lugs.
..Stiffler..
anyone have any pictures to show the finished product??
and what the bracket looks like all together??
thx
thx
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
Stiff,
Check the link as previously posted and scroll down. You will see the front and rear brackets with the third holes drilled on the top of the stock two.
http://www.ty4stroke.com/viewtopic.php? ... ts+perfect
Don't know how to do it in clickable form.
..Stiffler..
kool yeah seen those....but was just wondering if anyone has the finished look of the sled...
like how does it look from the side view...how low....
and also all put together meaning bolted all up to the suspension...
thx
Stiff
thx
Stiff
..Stiffler..
bump
