Black 1000
I thought some had added some foam to the seats on the 03-04. How much and what were the results? and where?
justin1635
- Mar 10, 2005
yeah, do a search for seat foam, cant remember who it was, but they spent like under 60 bucks and it looked real good
RX1 Yooper
I added 1 inch, and it is much better. I would advise going with at least 2 inches. There are other posts with pictures.
rx-1 blue reverse
I added 3" and loved it. 3" is about the most you can fit under the stock cover. Somebody put 5" in but he had to add material to the cover.
Here are some pictures of my sled.
http://www.rx1.info/viewtopic.php?t=8721
seat
I added 3" and I can not stress how much better the sled rides!!! I said it before,, it feels like a suspension upgrade, which actually it is. It cost me a whopping $8.50 for the foam. It took about 2 hours. Use an electric kitchen knife to shape it. Keep the lines smooth because small iregularities show through. I made mine about an inch narrower than the seat at the base and cut the sides on an agle to narrow about 3 inches at the top. At first I thought I screwed up and it was too narrow but after riding it for a day its great because you can slide down on the side to lean...
rx-1 blue reverse
Tony do you have any pictures. I would like to compare.
RX1Jim
Pics would be nice to compare. I'd like to add foam to the seat over the long, hot, humid misearble summer!!!
seat
I'll try and get one on here in a day or so.
Stay tuned....
Stay tuned....
I would also like to do this, and maybe a 1" or 2" riser for the bars if needed.
Phantom
- Apr 2, 2004
Has anyone added foam to the '05 seats?
rx-1 blue reverse
I added a 2" riser and rolled the handle bars fwd when I added foam
Tony VT What kind of foam did you use in the seat. Also how did you attach it to the old foam in the seat. Then what did you do ,just restaple the cover back on.
what kind of foam are you guys using?and where do you get it?
rx-1 blue reverse
I got mine @ the Foam Factory here in the Detroit Metro Area. I do not know what kind, they showed me some samples and I picked the one I liked the best.
schroedermn
- 31K
