Spicoli
- Dec 8, 2016
- Waterford, Ontario
- 2018 Sidewinder L-TX DX
The gurgle is normal. That’s the cooling cycling for the turbo.Mine often gurgles once stopped and shut off.
Every time I have checked my fluid, the rad was full, so just add fluid to the overflow tank. When cold, add to the cold line. I went a bit over that line at the beginning of this season and that is where it has finally stayed when checked cold.
Took a whole season (last season)to finally purge itself. This year it is staying full.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Always best to let them sit and idle before shutting off a turbo, it will cool the turbo enough and prevent boiling of the coolant coming out of it.
Alphadog
- Mar 6, 2015
- Appin Ontario
- 2018 Sidewinder
Absolute great pointAlways best to let them sit and idle before shutting off a turbo, it will cool the turbo enough and prevent boiling of the coolant coming out of it.
When the big Dog eats it has to cool down
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
My bottle is empty and it's overheating and I can't figure out why.
What's the proper burping technique?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Some are losing coolant so better look into the problem.My bottle is empty and it's overheating and I can't figure out why.
For new engines when I first fire them up, I always put the front end in air(tank at highest point) which means the rear tunnel needs to be lower then tank, so all air will rise and burp out the tank/res....run engine to open thermostat and circulate coolant, keep adding til its at correct level.
Dan
