zigwinder
I ride mixed terrain and conditions in New England. I don’t mind losing a couple top end mph, but want all-around grip corner-to-corner.
I plan on swapping from 1.25 ripsaw up to the 1.5 ripsaw2 track.
Running TD stock muffler multi-map with Dash flash. Dalton adjustable weights .
Stock otherwise.
Interested in others experience and setups like this.
Stock otherwise.
sideshowBob
I ran a 136 x 1.25 Ripsaw 2 on my Attak, before I change to an Ice Attak, and I found it to be an incredible track for varying trail conditions. The Ripsaw 2 IMO is a much better all around track in comparison to the original Ripsaw.
zigwinder
I think the stock 1.25 is a ripsaw 2 also, correct?
The 1.5 does look to have a different paddle pattern though.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I also plan on installing a 1.5 ripsaw , to replace the 1" track on my 22 SRX , as I want the corner to corner snap , from the coolest looking sled available.I ride mixed terrain and conditions in New England. I don’t mind losing a couple top end mph, but want all-around grip corner-to-corner.
Stock otherwise.
I will add the 240 or 270 SS Hurricane SM tune , along with studding of 1.8 +/-".
This should be a nice combination to get what I am looking for .
The other consideration would be to change the gearing slightly , to add to the snap .
What would the next step up in gearing be from stock ?
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I swapped out the stock Ripsaw 1" with a 1.5" Ripsaw 2 track on my '21 SRX and couldn't be happier. Awesome bite with this track and the durability is very good. Running a 250hp tune and the traction is great. I usually ride in very good snow conditions so I d0n't run studs. I would think that with studs you'd have yourself an awesome track in mixed trail conditions.
KillerBee
- Jan 1, 2010
- Waukesha WI
- 2018 Sidewinder LTX LE 50th
VX1R you have a great looking machine there!!!
zigwinder
Glad to hear others are doing this swap.
I like studs a little on the long side and was wondering if 1.8 (with the rear tunnel protectors installed) would have any clearance issues up front?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Funny you posted this. I was thinking about the exact same thing yesterday. I also am considering taking off the 1.25 and going with a 1.5 track on my new Winder.I ride mixed terrain and conditions in New England. I don’t mind losing a couple top end mph, but want all-around grip corner-to-corner.
Stock otherwise.
If I did this swap I think I would only run 2 studs per bar.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
X2 !VX1R you have a great looking machine there!!!
SidewinderConvert
4-Stroke Rookie
I am planning to do the 1.5" rip2 track on my 137" winder this year. I will be putting 4 studs per bar in it though. Planning to go with 3/8" of penetration on the studs.
zigwinder
What pattern are you thinking?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Well Newbie ZIG, where & what do you ride.
If you stay mostly on trail, look into the 1.5 STORM.
It's 1.5 in the middle & 1.25 on sides. In theory it helps you turn. I'm hearing great things about it for trail riders.
OH, and WELCOME. Where in CT are you from?
SidewinderConvert
4-Stroke Rookie
I am going to do all double backers up the middle (Exact pattern TBD) with the extra large head studs for single ply tracks. Not even going to consider doing single backers this time around due to the number of tearouts + broken studs I had this year with 144 in my 1.25" rip2. Also considering the stud boy pro-lite backers too.
zigwinder
Thanks for the Welcome! I ride VT, Pittsburg, and sometimes Maine.Well Newbie ZIG, where & what do you ride.
I live in Southington, CT.
My sled is a 2018 Sidewinder LTX 137.
thanks for suggesting the storm, but I bought the 1.5 Ripsaw 2 already. I did consider the Storm also though.
Turboflash
- Mar 18, 2019
- Southern MN
IMO, success, or lack thereof, with longevity of any studded track is usually highly dependent on how sleds gets ridden. Anyone can destroy any studded track easily by spinning at the wrong time.I am going to do all double backers up the middle (Exact pattern TBD) with the extra large head studs for single ply tracks. Not even going to consider doing single backers this time around due to the number of tearouts + broken studs I had this year with 144 in my 1.25" rip2. Also considering the stud boy pro-lite backers too.
Tuned, high HP doesn't necessarily equal stud destruction. I'm constantly thinking about what my track is on top of before pulling trigger.
