Fasttrax
Suddenly my apex wont even turn over. Turn on the key, dash comes to life but cant hear the whirl of the fuel pump and the starter wont engage when the key is turned to start. Relay maybe?? Need some advice.
Check the relay down by the battery.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
If not that check grounding blocks.
apex55
Grounding block behind primary clutch. I just went thru this.
Fasttrax
Thanks for the good advice, gonna go at it tonight. Will post results.
Fasttrax
Would that be the block that is wrapped with tape on the main harness??Grounding block behind primary clutch. I just went thru this.
HABS 1
- Oct 22, 2015
- corunna,ontario
yes
trosell14843
- Nov 17, 2014
- 2005 vector
Multiple little grounding blocks. I went through this on my son's vector. I found in the end a Bad kill switch-water leaked in and corroded it. If your starting a check down list put thus on it. Same symptoms
Sent from my HTC6600LVW using Tapatalk
Fasttrax
Just tapped it a few times and the fuel pump cut in. Is it just a matter of cleaning all the connections in the block and checking for disconnections? Or is there something else I should be looking for. Thanks again..Kirk.
Its a problem inside with condensation. It happens on the Nytros too.. I would get a new one.
Fasttrax
Sounds like a good plan. Thanks.Its a problem inside with condensation. It happens on the Nytros too.. I would get a new one.
HABS 1
- Oct 22, 2015
- corunna,ontario
no cut out the block and solder alltogeather as a unit and seal up
Why?? I wouldnt do that but to each his own.
apex55
I followed the wire harness to behind the primary clutch. There were 2. One with black wires and one with brown. I pulled off the metal cap on top using a small screw driver then using an eyeglass screw driver pushed in from the top and pulled out the wires and metal connectors. On the brown wire ground this worked. I cleaned them all used dialectic grease and reassembled. The black wire I couldn't get the biggest wire out so I cut then all and put on connectors then screwed them together . Sealed and tape back into the harness.
HABS 1
- Oct 22, 2015
- corunna,ontario
alot of times the plastic plug is burn , brittle or melted welded togeather, if thats the case garbage the plug
