Anybody use one these and if so can you send me a picture with it installed? I can't quite seem to get it to work.
duppypog
SERPAGS
Easiest thing. Remove the shroud, drop the bag in the front. Voila !
Thank you. The instructions said something about loosening the wire to the regulator????????????????????? And what do you hook the velcro tabs to?
blackattak
Wrap the velcro strips around the silver bar in the picture. They seal to themselves. Great way to keep a lot of stuff organized on the sled.
Mikecam
Keep my stuff in a plastic bread bag. I did undo the regulator and turned the braket around so it would swing more downward to give me more room.
Shootinstick
I haven't read any instructions to do so, but I also loop the rubber airbox cover tie down through the loop handle at back edge of bag.
Jim
Jim
It's a lot bigger bag and easier to get to than I thought it would be.
The regulator is no big deal, slightly loosen the nut, rotate down, tighten.
Bend tab on top over. Stick velcro tabs on frame beneath. Then just velcro loops, drop in.
true 5 minute job.
I keep my jumper cables and possibles bag in there.
true 5 minute job.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I moved my regulator downward too..and use a small duffle bag which i already had...fits in nice for the overnight trips..
this area does get some power in it so be aware of what type of bag you use..
dan
dan
ReX
Mikecam said:Keep my stuff in a plastic bread bag. I did undo the regulator and turned the braket around so it would swing more downward to give me more room.
I looked at turning the bracket around but the bracket is offset so if you turn it around, while it will tilt down more, the module actually sticks up farther.
It seems best to just loosen it off and rotate it down like the instructions say.
Swiss Sledder
The bag is great. I can hold a polar fleece jacket in it but I normally keep emergency stuff up there like a first aid kit, flashlight, tow rope, etc.
