JDMCRX
- Dec 13, 2005
- OTTAWA, ONTARIO CANDADA
- www.jbauto.ca
Hey guys been a while since I’ve posted !
Helping a buddy out 2007 apex , we did a full maintance on the sled and put in same
Heat range ngk iridums and now the sled is idleing rough and has a bog !
When you go to accelerate the sled bogs for a second then revs out . I’ve pulled the plugs out and they are all good so far and re gapped them a bit smaller.
This did nothing ! A few friends have been telling me that the bellows exhaust donuts can cause this , I did rag both tips and the motor isles lower but will keep running !
I’m not sure if bad exhaust gaskets can cause this issue or possibly I got a bad set of plugs !
Btw before we did this job the sled was running decent !
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
Any trouble codes flashing on the gauge cluster?
If you suspect the exhaust gasket (donuts) are bad you should probably do an inspection. If they are the stock donuts, it is not uncommon for them to go bad and leak.
Lastly, since you changed plugs, I'm going to assume that you had the airbox off. Go back and retrace your steps. Check hoses, sensors, correct spark plug arraignment. I've also know that the idle "circuit" on those sleds can be touchy. Check the one small filter inside the airbox that filters the air to the big hose that feeds the idle solenoid to make sure its not blocked up.
sideswipe77
- Nov 7, 2014
- Michigan
- 2012 Yamaha apex se
2011 Yamaha apex se
If you put a rag over the exhaust pipe and the motor did not shut off. You have bad exhaust Donuts.
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
X2 should stall out with rag test.If you put a rag over the exhaust pipe and the motor did not shut off. You have bad exhaust Donuts.
JDMCRX
- Dec 13, 2005
- www.jbauto.ca
Hey guys no codes on the dash !
Here is a quick video of what’s going on. I will have to Change the exhaust gaskets but do slightly leaking exhaust gaskets cause rough idle and bogging ?
Macheater
- Feb 7, 2006
- Niles, Ohio
- Niles, Oh
Based on your vid that thing sounds like its got a dead cylinder.
Either that or the TORS is trying to activate.
That idle speed appears awfully high. Will it come down to around 1400rpm once fully warm?
JDMCRX
- Dec 13, 2005
- www.jbauto.ca
I checked the TORS when you hold the throttle it bucks and warning light comes on ! It will idle to 1400
I’m going to slap the old plugs in ! I checked all the air box connections and other connectors nothing is loose
Macheater
- Feb 7, 2006
- Niles, Ohio
- Niles, Oh
While your swapping the plugs, do an inspection inside the plug caps. Make sure they're not all carbon'd up.
gvessey
- Feb 8, 2015
2021 Yamaha SX Venom
2015 Arctic Cat 7000
2022 Polaris 850 VR1
2017 Sidewinder LTX-DX (Sold)
2011 Apex SE Supercharged (Sold)
I know this isn’t likely the case but maybe worth mentioning. Any chance you got the wiring harness for the coils mixed up? I don’t know if it will even run mixed up never came across that before but maybe worth checking, I think the cylinder numbers are on a white tag on the wiring harnes.
JDMCRX
- Dec 13, 2005
- www.jbauto.ca
Hey guys so I re gapped the old 19,000km plugs and put them back in checked the coils also 1.6ohm and all connectors ! Fired right up and runs like normal ! There is a slight bog tho
when was the last time the primary clutch was cleaned and checked for worn parts? sounds like my brothers rx with worn primary bushings did before we swapped it out.
