ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
I went down the road of a Apex clutch on my Winder last year and had good results for the most part. The only draw back I have, is the engagement is jerky no matter how soft of a primary spring I run. I believe the issue is caused by excessive clearance between the belt and clutch face. Beside taking the clutch apart to change the split moon washes, a option not available to me for lack of specialty tools. How can I close this gap up?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
911 cover! HAS A SHEAVE adjuster on it.
Call Terry over at thunder clutching.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Did you also switch everything over from sidewinder clutch to apex clutch, spring, rollers,and weights?
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
I did not switch the rollers. But yes to spring and weight.Did you also switch everything over from sidewinder clutch to apex clutch, spring, rollers,and weights?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I noticed that with the Viper clutch I installed the area where the rollers go is narrower than on the winder primary. My gforce rollers wouldn't fit with washers so I went back to TP rollers and stock viper washers.
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
I think that's the route I will go, but the price of almost 400 Canadian dollars is the reason for this post. I was hoping I could find a more economical way.911 cover! HAS A SHEAVE adjuster on it.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Thunder told me to switch everything even rollers. I believe they're different sizes not saying that's the issue. I also would suggest the 911 cover I have it on both my apex and sidewinder.
fourbarrel
Building a collection one sled at a time
- Sep 23, 2004
- New Brunswick
- 2019 SRX
I have thought about buying a 911 cover too and the same reason as yours is the only thing holding me back lol.I think that's the route I will go, but the price of almost 400 Canadian dollars is the reason for this post. I was hoping I could find a more economical way.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
One last thing. Is the belt have a lot of miles on it? A new belt might help some. But your two options otherwise are 911 cover or grunt tools and re shimming the spider.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I just put my g force rollers in my sidewinder clutch. Wow are those nice. I can tell the tolerances are really tight. They need to wear in a touch. But I’m really impressed with his rollers. DMC I believe you were one of the first to run these. I followed your lead. Sucks they don’t fit as I’m guessing they last forever?I noticed that with the Viper clutch I installed the area where the rollers go is narrower than on the winder primary. My gforce rollers wouldn't fit with washers so I went back to TP rollers and stock viper washers.
DMCTurbo
- Nov 12, 2005
They are very nice! I was hammering through TP rollers in a weekend, the Gforce made it through 2 weekends and still fit like new. Unfortunately they are now sitting in my clutch parts bin as they'll only fit the Viper clutch with no washers and that doesn't sit well with me cause I think they'd wear into the aluminum.I just put my g force rollers in my sidewinder clutch. Wow are those nice. I can tell the tolerances are really tight. They need to wear in a touch. But I’m really impressed with his rollers. DMC I believe you were one of the first to run these. I followed your lead. Sucks they don’t fit as I’m guessing they last forever?
I bought a set of Gforce rollers also to try out. I've never really had roller issues however, as I got over 8000kms on my original set.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Let us know what you think. Mine need some miles on them. They are a little tight. Not worried but I’m pretty sure you will notice what I mean. Tolerances are really good. Imo.I bought a set of Gforce rollers also to try out. I've never really had roller issues however, as I got over 8000kms on my original set.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Did you get the bronze bushings in those?
DMCTurbo
- Nov 12, 2005
That's what appears to be in my gforce rollers.Did you get the bronze bushings in those?
- 26K
- 14K
