emr333
I'm having trouble with my 2009 Apex MTX. It was a totalled sled that I put a new subframe and engine in. We put it all together and it started and ran excellent. Took it outside the shop and drove it a few miles around the yard just to make sure it was working well. After sitting outside for a little while we went to start it again. The sled then wouldn't start and would only crank over. Now the sled won't start, displays code er-1 and the fuel pump solenoid clicks constantly. Every once and awhile the fuel pump solenoid will quit clicking and run fine. If cranked over long enough the sled wire fire and run perfect for a few seconds then shut off again. Put the sled back in the heated shop over night and is still displaying the same issues. We tried swapping the speed sensor out for another it made no difference. Any help would be appreciated.
blue er
that's usually an ecm error code, check to make sure connectors are pushed in all the way and check grounds
blue er
er 1 condition open or short in blue/yellow wire, malfuntion in digital guage or malfuntion in ecu, taken from my service manual
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Don't have to worry about the gauge as sled runs without gauge pod, unless you try running it with the pod disconnected.blue er said:er 1 condition open or short in blue/yellow wire, malfuntion in digital guage or malfuntion in ecu, taken from my service manual
Fault Diagnostic
Code No. Symptom Probable cause of malfunction code
Er-1 No signal are received from the ECU. • Open or short circuit in wiring harness. 07
• Malfunction in meter.
• Malfunction in ECU.
• Defective wire connection of the ECU coupler
emr333
Well I went through and checked the entire wiring harness for wear spots as well as took every connection apart. I then cleaned every connection and filled them with dielectric grease. All that I've seemed to accomplish is now the fuel pump solenoid clicks faster
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Have you checked the voltage at the fuel pump relay, mine did that when the battery was low. But never had the ER-1 code.
emr333
Voltage was 12.8 at relay. Tried a different battery as well with no luck. Might try a different fuel pump
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Unplug the fuel pump and see if the relay still clicks.
blue er
I had a similar issue on my apex several years ago and it was a bad wire in the harness to fuel pump relay, wire had green rot and high resistence, still showed over 12 vts on the meter but not enough current to light a test light though, it was the wire that started in the starter relay brown/red i think.'
also try wiggling the harness gently while turning the key
emr333
It stops clicking when the fuel pump is unplugged
blue er
check to see if a test light will light up on the fuel pump wire when you cycle the key
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
I'm wondering if the fuel pump is seized which is drawing high current causing the relay to chatter.
emr333
It will still chatter when a test light is plugged into it. It will work sometimes for a few seconds then start chattering again. Felt the ECU while it was doing it and it was very very warm in one corner
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Is the fuel pump actually running?
blue er
did you try swapping a different relay in there?
