4Fighter
Leaking at the coolant inlet into the valve cover. I put a new o-ring in it, buttoned it up, took off down the road and now it's leaking even worse. I know where it's leaking, I know why it's leaking, I don't know what the trick is to keep it sealed - Blue RTV? Double o-rings? Appreciate any help - Thanks!
Jona$
Master
did you lube them up so they went in smoth, easy to deform them otherwise, been there done that.
4Fighter
Hmmm...No, I didn't use lube on them, but the other set I have from my Attak has a white sealant applied to the o-ring/around the tube. Makes the o-ring look more squared, and this was how it came from the factory - I thought I was being handed the wrong part at the counter.did you lube them up so they went in smoth, easy to deform them otherwise, been there done that.
4Fighter
OK so THAT was a tricky one. Turns out the hose had a tiny crack in it so coolant would drip/spray and pool in the valve cover until it would run over and burn off. Wouldn't show-up at idle.
Wow. Good find.
Was it the hose the went to the fitting in the head or a hose from above coming from the coolant tank?
