Yamaha205
Would a Apex exhaust add power to a RX-1?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I don't think so. The only real difference is one is made from Titanium.
Yamaha205
the design of the exhaust isnt exacly the same
RX-1
Apex
RX-1
Apex
apltx08
The HEADERS on a APEX are longer for 1 thing, you'd probably have to change HEADERS and EXHAUST all from the APEX, I'm almost positive it would fit.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
You would also have to change out the rear plastic. Exhaust covers, end cones, etc.
I'm told the rx-1 headers will fit the apex, so it should also work the other way around?
All this work, and most likely no gains other than saving a couple lbs, if that. I do not believe there is any power to be gained from this.
Yamahammer485
apltx08 said:The HEADERS on a APEX are longer for 1 thing, you'd probably have to change HEADERS and EXHAUST all from the APEX, I'm almost positive it would fit.
Yes, exactly. There was a wirte up along time ago on someone doing this.
Essentially, its not worth the time...
- 8K
