Nytro94
- Dec 6, 2015
- New york
- 08 Yamaha Nytro RTX
5100 miles, and on the last ride of the season. It got really loud and backfires so i cracked her open and found 2 of the 3 flex pipes broke and cracked, can I replace them with pipes off of my buddy's Apex that he had wrecked that is an 09 and my nytro is an 08. Are they the same length and OD?
No they are a different Dia. pipe. I have 2 extras at my shop.
Nytro94
- Dec 6, 2015
- New york
Are the ports to the head the same size?
U can get them to work if you bore out the flange holes and then you have to use the same clamps on the head pipe from the Apex. You also have to cut the excess off the pipe that stick past the gaskets.Are the ports to the head the same size?
They can be worth the time. The race sleds used them with an aftermarket header.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
The Apex pipes are a smaller diameter.
Sent from my SM-N910R4 using Tapatalk
The 2011 and up pipes are larger.
Not the newer Apex pipes as stated above.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have some nytro flex pipes if you want something that bolts right on.
rxwhopper
has any one used the apex flex pipes? i have 4 apex ones and need one for my nytro. at this point im not worried about loosing a bit of hp. is it the bolt holes that need to be bored bigger mr sled ?
The holes need to be bored bigger and the Dia at the donut side is different size. It can work with the other size clamps.
