rhoag
If you are only bottoming occasionally then you are using your full suspension and that's a good thing.
I was reading the pages about suspension tuning from the manual I got from the dealer and it called the RA aduster a rebound damping adjustment and the mono EC compession damping. I am assumiing that's a typo and both the RA and EC control compession damping? I also found in the manual it says the minimum unloaded spring lenth on the ohlins monoshock is 265mm (10.43 in). What is .43 of an inch? My spring is at 10 3/8 which gives my 225 pounds a 44mm sag. I would like to get this closer to 40mm, it looks like I have alittle room to adjust. Maybe I should buy a metric tape measurer. I would like to be on the high end of ride height.
