hokkkey
- Jan 15, 2009
Brand new (less than 300 miles). This has happened three times now. After starting the machine and letting it warm up (from a cold start and it had not been ridden in days), it doesn't want to take off until you are way up past 8000 rpm. Emergency brake is not on and doesn't appear to be hanging up. I always lift and drop the rear end a few times to break away ice from underneath. Anyone experience this?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Once you're free, is everything else normal?
Here's some things to try out:
- You say you free up the suspension, but do you also free up the skis? Sometimes the skis freeze to the ground.
- Raise the track off the ground with a track stand and see if you can turn the track by hand.
- Look at the drive belt before starting the sled up and see if the belt is at the top of the secondary where it should be.
- Check chaincase fluid level as well as chain tension as per manual.
Let us know from there.
hokkkey
- Jan 15, 2009
Appears to be normal once "free." Ski's are not frozen - has happened twice from inside the trailer and today it was 40+ degrees. Very warm inside the trailer. Will check and see if I can spin track by hand. Will check drive belt at secondary. Looks like chaincase fluid level is at the "non reverse" level where mine has reverse. Will check chain tension...given the mileage I assume the dealer had this correct at delivery.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Another thing you could look at is the chaincase fluid closely. If it's milky, it could have water in it and may be frozen at start up.
daver
or it could be empty and your chain is rusted together. My buddy got his chaincase oil changed except the dealer forgot the important part...the refill!!!!!!! if it's brand new, the dealer may have forgot to fill. just an idea.
Dave
Dave
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
e brake on ??????
Iceman57
Is the clutch engaging? If so does it act like it does when your track is frozen in the morning or do you feel the clutch engage just before it moves?
duck57
check slides
check slides they get warm and melt into track clips
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
You mentioned IN THE TRAILER, You get huge temperature swing's from night to day in side a trailer causing a lot of condensation on motor and clutches and causing major belt slip. Do you run it good on a stand before trying to take off? This will warm up and dry the clutches if wet or frosty. kviper
