f7lee
anyone know what angle helix came in the 06 apex rtx?
51/43
f7lee
thanks turk. do you know if i buy say a dalton helix it is cut different than the stock one? because i hear alot about cutting the stock helix to get alittle more from the stock setup. what do you think?
I never saw any gains from cutting the helix because you need absolutely perfect conditions & a real long run with perfect gearing. If all those criteria are met you might ; maybe see a minimal gain. A Dalton helix should be close to the Yamaha one but the stock helix works just fine.
f7lee
thanks turk, your opinion is always valued.
