Zachary
I have an apex with no tunnel ID. Is there any other frame numbers or anything? Can I get another one issued with my numbers on it? I do have registration and everything. I'm new to having a sled good enough to be up to date on the trail. up til now has just been old farm sleds. Thanks
![](/styles/admin.gif)
![](/styles/vip.gif)
VIN number is on the right side tunnel stamped in... what plate are you talking about?
Zachary
There is nothing there, no stamping. I've seen them as a sticker or something. It's a clean tunnel. The sled is an 06 with almost 10k on it. maybe it came off or it's an aftermarket tunnel?
Has to be a aftermarket tunnel... it doesn't come off, they are stamped into the aluminum.
Zachary
Here is a picture if I get it to work. Apparently you have to host your pics you can't upload them?
Zachary
So are there any other frame numbers elsewhere?
You can upload a picture... click upload file and add it...
No
Zachary
Its under that tunnel reinforcement.
Zachary
Do I need those numbers for anything if I have registration?
Zachary
The big one that says Yamaha or the small one?Its under that tunnel reinforcement.
The big black one ... under that is the VIN number... if you have the reg card and info you dont need to uncover it unless you get stopped by the DNR and they want to see it.
Zachary
Awesome! Thanks! MrSled, I have only posted on 2 threads and you have helped greatly on each. Thank you!!The big black one ... under that is the VIN number... if you have the reg card and info you dont need to uncover it unless you get stopped by the DNR and they want to see it.
tator
big one.
- 149K
