GT Mills
What are the causes for an Apex (2011) to go into limp mode - with the TORS bypassed?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Low oil pressure will trigger limp mode on the 11+ motor. Gauge would display Low oP as well if that was the case.
- Jun 28, 2004
- Clinton, Wi.
Speedometer sensor will cause it as well. Mimics TORS. Typically caused by a bad driveshaft bearing.
x2 on what viper_dave said. that is what my 11 did on the trail when it failed.
GT Mills
Just these two things? OK. Thanks you guys.
