GotJuice
I have an Apex Mnt. and wanna run two or three bottles for obvious reasons. I have relocated the battery to the rear and wanna run two sets of filters to the throttle bodies. ( like the GYTR filters Hauck offers ) haven't heard much from anyone on there quality, performance etc but seems lke a nozzle in the top of each set of filters would work nicely. I'd like to run these filters and a 4 lb Carbon fiber bottle in the place where the stock air box is with out the battery there. Along with another 4 lb bottle in the rear.
A 60 h.p. shot running my clutching at 10500 off the bottle and 11500 on the bottle using a PCIII and ignition module from Ulmer racing. This way I can keep the stock H.P. at the correct clutching and run the 60 h.p. shot without hitting the rev limiter. I'm wondering if I remove the air box and the battery is reloacted will I have enough room in there to run the 4 lb bottle with the filters and maybe allowing me to run another bottle in the nose where everyone usually does? There's a lot of room under that air box when it's removed. Last thing is how long will 8 lbs last with 60 h.p shot if I leave it on full throttle activation and using it for jumping and climbing periodically through out the day. All input appreciated!
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
I'm not sure about the Apex mountain but you can run a 4lb Carbon bottle in the nose and one in th trunk with about 30 seconds of dremel work.
60 shot will spray about 1 lb about every 12 seconds or so. maybe even 15 seconds...i don't remember.
If you get 15 seconds per lb then....2 minutes of spray give or take a few seconds if your running 8 lbs.
GotJuice
thank you
Thanks for the information, can anyone elaborate on the filter option to remove the stock air box? That would give me a lot of room in that area for another bottle or other storage. Thanks
