Blue_Blood
- Nov 3, 2015
- sarnia
- 2010 yamaha apex ltx gt
Hey everyone weird question last winter on the coldest night of the year my 2010 apex started in the trailer and sputtered and died and would not start again the plugs were only a year old but ended up taking it home and changing the plugs and fired up like nothing happened I was curious if it could be a relay I had that problem up north with my nytro but I never had a code or a light any ideas ?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
relay would cause it not to start at all I would look at the stator awefully close sounds more like that it can fail and then work and fail again before it fails totaly. there are lots of other things that symptom could be this is just the first that come to my mine sound like a familar story.
Blue_Blood
- Nov 3, 2015
- sarnia
Ya makes seance just never before had a problem and for the rest of the season not even a hick up seams strange
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Does that sled have the updated relay (red) for the fuel pump?
Blue_Blood
- Nov 3, 2015
- sarnia
Don't believe so but my nytro had a code and engine lite when that happened ?
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Helps to know the code #. Apex could have been a frozen relay, I would replace if it the old style.
HABS 1
- Oct 22, 2015
- corunna,ontario
use dash cluster and check stored codes just to eliminate,if theirs ones in there write down then zero them (clear them)
Blue_Blood
- Nov 3, 2015
- sarnia
Ya that's the thing it never had a light or code or anathin !
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Have you checked the relay yet?
Blue_Blood
- Nov 3, 2015
- sarnia
No
Blue_Blood
- Nov 3, 2015
- sarnia
- 8K
