Apex Radar Run Setup
Bigshooter06
I'm running an 06 RTX with 144 studs, Hauck Pipes, and Fuel accelerator. I have a set of 98 SX shocks that I've heard work well for the front. It is a 1000 foot strip that we are going to run on. Looking for what setups work well with what I have to work with. Thanks
Is there any tricks to getting the rear suspension as low as possible. I ask because I have heard from some guys that if only the front is lowered it can be interesting trying to stay straight.
tie the front strap for take the same bolt at bottom and put a 1 inches or 1 1/2 inches shim between the piston and bottom of cylinder of control rod
attach the front and now your sled is near the ground but no transfer.if you want transfer you need to cut the shock spring to length your shock is compressed
