HABS 1
- Oct 22, 2015
- corunna,ontario
i have mtx riser now 2.5 inch higher with stock cables , if i do wrp will need another 2, 4-5 inch toatal , mabe more! i would need cables! like the stock looking seat anyway , thinking all black seat no stripe off a 2010 ltx with 4 stroke gen on side and mabe just stiffen up seat foam a bit!You don't need to change cables with WRP seat. I added 2 inches and reroute one cable. A friend has the seat and likes it.
zr8000
- Dec 29, 2005
I bought a 3.5 inch rox riser I found it was too high for my liking even with my WRP seat so I went back to a 2 inch rox.
I had purchased mountain cable for the 3.5 inch and still have it in the package if you change your mind for some reason on the higher seat.
HABS 1
- Oct 22, 2015
- corunna,ontario
ok thanks appreciate it , ill see what happends!!
I rode a Attak with the WRP for a 20 min and liked it except the tacky top. I like to slide from side to side in the corners. I would probably use some Armor All on the seat.
What windshield do you have? Lots of wind.
zr8000
- Dec 29, 2005
I have a mid height windshield.
Yes, the WRP seat is sticky and firm I became used to the boss and I like it that way now.
I have found the wind is not too bad. This sled is actually warmer than what I've had for a long time.
4bangdan
- Sep 8, 2005
- Fort Kent, Maine
- 2004 yamaha rx1 2015 yamaha apex xtx
You really dont know what you would be missing without a wrp seat. Its the quality of the foam thats the real difference. When i swap with other sleds oem seats i cant believe how hard and crappy they are. Dont skip the chance to make a great upgrade to wrp.ok thanks appreciate it , ill see what happends!!
HABS 1
- Oct 22, 2015
- corunna,ontario
u got me thinkin! wrp only 30 bucks more than oe, wrp still has rear trunk when installed? did u install cover and foam yourself? was it easy? mabe ill get 4 stroke gen stiched into side of wrp seat ? or apex or ?!!!!
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Definitely do the WRP over a stocker. no comparison. Still has trunk and its much deeper to throw a couple extra beers in!! easy installation, WRP has a video online. or upholstery shop usually $30-$40 cash installation.
HABS 1
- Oct 22, 2015
- corunna,ontario
thanks
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
X2, WRP all the way. Best $300 I've ever spent!Definitely do the WRP over a stocker. no comparison. Still has trunk and its much deeper to throw a couple extra beers in!! easy installation, WRP has a video online. or upholstery shop usually $30-$40 cash installation.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
X3 WRP Seat.Similar threads
