FLYBYU
Put the fuel pressure gauge on it and it went to 40 psi. Then when i started it and ran it, the gauge went crazy flickering between 35 an 42 psi and it's constantly growling. Well, what do you guys think?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
leaky intake valve......... or valves
FLYBYU
would the plugs tell the tales of this. They were all perfect color.
FLYBYU
This is the latest. I pinched off the fuel return line going to tank to test the fuel pump. What i found was that when i turned the key on the pump bounced up to 80 p.s.i. and then bounced back and forth between that and 50 p.s.i. the whole time. It never was steady pressure. Didn't hold pressure either. And no there was no fuel going back to tank. Well what do you guys think? Please tell me, this probally the cause. It makes sense. When i go into the boost the fuel pump can't keep up because of the fluctuation of pressure.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
Then... you might check fpr?
If fuel pressure would be so high up then idle would be unbelievably rich!
FLYBYU
By pinching the return line it deadheads the pump which creates twice the pressure, bit it suppose to be steady pressure not bouncing all over. I read there is a check valve in these pumps which is suppose to hold pressure which it isn't doing either. Please if I'm wrong this please chime in before I spend $150
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Fuel controller went bad if it ran good one pass and won't run the next. Once it builds boost it can't get the fuel it needs.
BOXERZ
- Aug 23, 2010
JUST HAD SAME PROBLEM BAD CONTROLLER . IF OLD STYLE PLUG INJECTORS BACK IN AND START SLED IF IT RUNS( DO NOT HIT GAS) ITS A BAD CONTROLLER
FLYBYU
It's not the fuel controller as it is the rb3 and does not connect to the injectors there. And I already tried that. I also did find a little exhaust leak right after the downpipe in the tunnel.
FLYBYU
Hey Mike, did you read how the fuel pump is acting though. It should hold pressure with the return line clamped. It should have a steady pressure build, not bouncing all over the place. Right?
and that is with the engine off and return line clamped shut
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
yep fuel pump should pressure for quite a while.
FLYBYU
This morning i deadheaded the pump before the fuel rail but after the pressure gauge and the pressure bounced up and down up to 80 p.s.i. then quickly fell to 0 when i turned the key off. Ordering a pump today.
FLYBYU
Well I went to the nearby advance auto parts and they actually had the msd pump sitting on the shelf. Went and installed and poof, fuel went to 40 psi and stay there. Shut off the engine and it still stayed there. Well i believe the problem is solved. just need to ride it now and see. I have a little exhaust leak just as the down pipe goes into the tunnel. My wife wanted me to thank you guys as i can sleep now. Sticky for testing failing fuel pumps?
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Thanks for the feedback, good to know we were guessing in the right area. Will keep this in mind for future troubleshooting...mbarryracing said:...I agree with TBird, it sounds like fuel... maybe pressure related.
What kind of pump are you using? Stock or inline high pressure? Maybe the pump is going away...
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
BOXERZ - Welcome to the site. Please add your location to your user profile, it's a site requirement.
rxrider
TY Management
rxrider
TY Management
- 6K
- 7K
