APEX Windsheilds & Mono Springs
ridgerunner1
Massachusetts
This may be silly for some of you, if not all of you... How do you measure windshield hieght? Specifically, point A to B. I want to purchase a windsheild that is approx. the same hieght as my 04 Warrior which performed quite well. Also, for those Big Boys out there (I'm one of you), are we buying the GYTR Optional Mono Spring that is on the Yamaha site? There has been a different part number posted on this site which is why I'm asking about a subject that has been well covered.
Ridge
what is your weight with gear on?
i picked my sled up yesterday(rtx).
when i sat on it the suspension barely movedi am 235lb.
my plan is to ride it first and see. once it breaks in some it will be different but right now it seems ok<
I'm about 245, though I gotta be back to 220 or I'm going to need some new expensive gear that I prefer not to buy as my Rima gear is like new. I read that Snowgoer article, specifically the crashing through, which my back can't take much more of, so I figure the new spring is worth it. Whre do you ride leader? Where did you get your RTX? Will you change the windsheild?
