sx7001
- Jun 28, 2003
- Sidewinder
Just google "star suspension xtx"
icebreaker
- Aug 18, 2010
- Southern wisconsin
- 2011 xtx
Does anybody have the stiffer spring number for the front shock??????Got that, center shock with heavy spring and kit, did that. It's the very rear shock, the clicker that seems to have about 1/2" of free play/slop up and down at the beginning of the stroke before it does anything. I didn't notice it before i did the kit. Guys with or without, does your REAR shock do that, is it normal, did you do anything to the clicker when you installed the star kit?
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
8CX-47336-10 Is the part number some have said they use, I have not been able to find a spring.
sx7001
- Jun 28, 2003
- Sidewinder
The yamaha spring is no longer available. You can use this BRP spring, part # 503192217. Inside diameter is a little bigger but it gets the job done.
icebreaker
- Aug 18, 2010
- 2011 xtx
Just ordered the doo spring $45.00 from doo dealer. Thanks guys!!!!The yamaha spring is no longer available. You can use this BRP spring, part # 503192217. Inside diameter is a little bigger but it gets the job done.
Caveman
- Sep 13, 2012
- New Hampshire
- Yamaha, Polaris, SkiDoo.
The heavier Yamaha spring is off an RX1 and there's still a few floating around. I found a new one on ebay a month or so ago. I sent to Star with the center shock for rebuild and shim to prevent suspension damage if the limiter straps break. The rear clicker shock is at Hygear now for rebuild, revalve and bigger hose. They supposedly have a good valve spec for the rear shock running in a Star suspension. The star kit has clearly freed up the CK rear skid with full travel and no sag. With the star kit and both shocks revalved, the XTX should finally ride the best it possibly can.Just ordered the doo spring $45.00 from doo dealer. Thanks guys!!!!
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
The Warrior uses a 4kg-mm spring can that be used in the XTX? Optional 3.0 to 5.5
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
I've installed the Warrior centre shock in both the Nytro and Apex XTX. Works good and the shock doesn't blow threw the stroke at all. It's also is about 1/2 inch shorter so it lowers the front of the sled, which in my opinion makes it handle better.The Warrior uses a 4kg-mm spring can that be used in the XTX? Optional 3.0 to 5.5
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I bought the 3 kg spring for the middle shock from Pioneer which is Yamaha # 8ES 47337 00 00 , to go with the Star kit .I've installed the Warrior centre shock in both the Nytro and Apex XTX. Works good and the shock doesn't blow threw the stroke at all. It's also is about 1/2 inch shorter so it lowers the front of the sled, which in my opinion makes it handle better.
may have it too tight , as there is very little bottoming .
The ride is getting better with every addition , and adjustment .
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Star kit is almost finished in the XTX. Heavier Doo Spring on the center shock not sure how much preload to give it about a inch from the top of the threads now. Got the 5 position adjusters but they look back wards to me. They are labeled left and right but to go from soft to medium you would have to crank them towards the spring rather then away.
attak 06
- Jan 12, 2009
- Deer Lake, NL
- 2011 Apex XTX
yamajohn
- Apr 25, 2006
- Sudbury,ON
- 2013 apex xtx
I got my shocks revalved and the doo spring from star and after riding it all last season with just the kit done, all I can say is you have to do the complete set up. The kit itself works good but with the shocks done and heavier spring its a whole other level. I can pound it now on rough trails, I am riding way faster on beat up trails and it takes it with ease. In my opinion, it is really the only thing you need to do to an xtx to make it better.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Thanks I have those, I was looking to see where others had theirs set!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
See I don't get what star is saying about the xtx skid sagging a lot,heck mine is anything but sagging,and I have it on the softest setting,if his kit softens it up how the heck do you than keep it from bottoming out,and how do you keep the front end down under power thru a corner?
