skyboz
Thanks for the info. It sounds like the Simmons can handle some aggressive corner to corner riding!!!
BETHEVIPER said:simmons work better the faster you go, the slower you go is when they start steering harder.
Before i modified them to use the skidoo carbides they turned even harder. I installed the skidoo carbides centered under the spindle. stock they come with the carbide trailing the spindle which adds straight line stability (they dont need any extra) but also adds to steering effort. This modification makes the ski safer and steer easier.
the Arrows turn easy at slow speeds.
Weight
Arrow 7lbs 11.8oz
simmons 8lbs 9.5 oz
curves 8lbs 12 oz
percision 8lbs
