jrice1987
So I just replaced exhaust donuts with copper ones and put rags over exhaust. The sled almost completely stalls out but does not. New donuts not sealing? Should it stall shut off completely with rags over exhaust?.
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
It should completely die if you close off tailpipes , must have a leak
jrice1987
I just tried again and it and after 30 sec of closing them off it died
Give them time to heat cycle a few times..
jrice1987
Ok thank you
when i do exh dounuts, i always make sure the clamp does not turn on the pipe when i am installing the new ones. last one i did had to be filed on the clamp stopper twice before they quit turning and the flanges where good.
I always file the clamps about .040 so they will pull tight and help seal as well as never rotate.
