my 06 attak was acting strange, it was as if i was turning the key off and on while driving. it became worse as i tried to limp home. the motor would stop and i could sometimes start it right up again and sometimes the starter would just turn and it wouldnt fire. when it wouldnt start, i turned the key in the on postition and i couldnt hear the fuel pump. so i swaped the fuel pump relay switch with the headlight relay and it didnt change anything. now i can start the sled but if i press the throttle it simply stops and the red light and yellow warning light is on with a temperature sign and an engine sign and on the bottom it reads ERROR 1.
any one have any idea im clueless.
Check your driveshaft bearing. Same thing happened to me. Bearing fails..takes out the speed sensor..ECU shuts down the sled. It wont start then 5 minutes later it starts fine but shuts down again as soon as the sled moves. if you unplug the speed sensor conection it will move ..thats how the mechanic got it in the shop. mine went at 12500 km.Search Err 1
i just looked under the secondary and theres a handfull of ball bearings. the sprocket on the driveshaft is actually touching the speed sensor.
Thanks for the reply.
