Tim Fraser
- Oct 10, 2014
- Leicester, NY
- 2005 Yamaha Warrior
Just purchased a 2015 Triton clamshell and I want to protect the axle before it gets too rusty. What does everyone use on the axle to protect it from the salt/sand etc? Does anyone coat the aluminum beams underneath the trailer? If so what do you use?
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Following......
Look up "rust converter" and maybe just a simple undercoating?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I have used fluid film to get at the areas around the torsion spring and wheel axle. Otherwise I have crawled underneath and used cheap axle grease to coat it.
I bit messy but seems to keep the corrosion at bay.
MS
MS
been getting my current trailer undercoated every year with the truck.
I use mastercoat permanent rust sealer. The company is in West Milford NJ. The coating comes in quarts. It is aluminized paint you can weld over. It goes on with a foam brush or foam roller. It self levels and a quart goes a long way.
I just did my father's F-250 frame with it.
I believe I did 2 coats and used 1 1/2 quarts with doing tank shields and leaf springs.
lockburner2000
- Feb 15, 2010
- Bruce WI
- 2010 Vector GT
Fluid film it every year along with your truck!!
cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
Try Krown and comes in a can
https://www.krown.com/products/aerosol-products/rust-protection-and-lubricant/
Tim Fraser
- Oct 10, 2014
- Leicester, NY
Thanks for all the replies going to coat it this spring for sure.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
truck bed liner spray works great
- 17K
