**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
did I read somewhere that micro belmont makes a stronger shaft?
sj said:did I read somewhere that micro belmont makes a stronger shaft?
mdkuni said:sj said:did I read somewhere that micro belmont makes a stronger shaft?
About 8 posts back on page 5.
I ordered a 09 rtx apex but have a 05 900 fusion with 5000 hard miles on it. I had a drive belt last me 2500 miles. If the updates are done and you have a good fusion mechanic that did the updates its not that bad of a machine. Plus I picked it up for 5200 cad had a thousand miles on it with a years warranty left on it. still running strong and starts every time on the third pull and no axle problems.Snomad said:I have never broken a drive shaft. And if you think that this is a problem that requires addressing by Yamaha how about the Doo dealers that are welding the splines on the new drive shafts on those machines??? 0 miles, new machines before going out the door. That sounds like real confidence in 100% failure to me. And how about the first year 900 Polaris Fusions and their drive shafts?? Put it in perspective.
sj said:rex...you just jinxed yourself~
mdkuni said:I called Micro Belmont today and spoke with Gary. A great guy! Website: www.micro-belmont.com
$175 for a drive axle that IS stronger then the stock one. Very straight forward guy. He said it is not likely that you will break this axle, but it is possible. Everything can be broke!
He also sells a socket and tool for the drive axle to remove the top nut.
I will replace my drive axle at the end of the season and hope to put my worries away.
