Diceman
- Mar 26, 2006
my o4 Grizzly has been back firing.....always when I let go of the throttle...maybe do it 3 or 4 times everytime out....was wondering would the needle and seat have anything to do with it?...it was sticking before and I just tapped the carb to loosen it up or free it...it runs fine, starts fine too.....any suggestions.....??...Diceman
clutch
My 06 would backfire all the time. It seemed that the dirtyer the air filter was the more it would back fire. When it would pop several time an hour I knew it was time for a cleaning.
Diceman
- Mar 26, 2006
clutch said:My 06 would backfire all the time. It seemed that the dirtyer the air filter was the more it would back fire. When it would pop several time an hour I knew it was time for a cleaning.
what do you use to clean your air filter?....are they always just cleaned or do you eventually buy a new one???..how much are they?..Thanks
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Adjust the valves if you haven't done it in a while. The intakes tend to tighten up. Keep your air filter clean. I remove the sock and rinse it with kerosene then resoak it with oil. Replace the sock if needed. They run around $12 to $15.
clutch
I always have two air filters That way one is always oiled and ready to go on the quad.
- 14K
