Firstyama
- Sep 30, 2017
- Windsor
- 2017 Yamaha Viper LTX LE
Anyone’s viper ever backfire on deceleration? Doesn’t do it all the time, just occasionally, usually after I was just running pretty hard. Anything to worry about? Bone stock 17 Ltx
Firstyama
- Sep 30, 2017
- Windsor
Also, rode with a Cat XF7000 and his did the same thing but not as much, also stock
Angus viper
- Jun 29, 2007
- SW Ontario
- 2015 sr viper se
My 15 does it on occasion
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
i think they all pop a little on decel
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Mine has also the odd time
Pat Cat
- Nov 27, 2016
- Granby, QC Canada
- 2016 Arctic Cat ZR7000 LXR 137
2011 Arctic Cat Z1 1100 N/A
Previous:
2014 Arctic Cat ZR7000 Sno Pro 129
2013 Arctic Cat XF1100 N/A LXR 141
2009 Arctic Cat TZ1 LXR
2009 Arctic Cat T570
- Granby, QC Canada
Mine also
Yamatuner
- Jan 19, 2016
- Escanaba
- 2015 Yamaha Viper 141, 2017 Yamaha Sidewinder 137, 2017 Yamaha YXZ1000R
My sled used to but after reflash fueling was a little more accurate. A tip is to not completely chop off the throttle. If you try to keep it open even 5% it eliminates the ultra lean 19-20 AFR and the backfire that accompanies it.
Yamatuner
- Jan 19, 2016
- Escanaba
From my own experience... May differ with other sleds/tunes
Firstyama
- Sep 30, 2017
- Windsor
Ok thanks, just worried there was a problem
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
The sleds that I have seen do this have all had cracked header pipes. Might want to check that.
Yamatuner
- Jan 19, 2016
- Escanaba
I live by having an AFR gauge. This would show you if it was in fact a lean condition, if the sensor is properly installed....... I personally wouldn't be concerned but it never hurts to "nut and bolt check" your sled at least once a season.
Yea I over corrected the lean spot the new flash gave me but still better mpg than all the guys I ride with except Phazer. Had alot of backfires before I did this. Non since but it never hurt anything just keep eye on header and if 14,15 the stock can which is known to crack open. First sign is a rattle and the insulation being blown out of shield covering it.
jeff_yam
How did you correct it? By adding a little bit of fuel at 0 and 2% of throttle between 1500 and 3000 rpm?Yea I over corrected the lean spot the new flash gave me but still better mpg than all the guys I ride with except Phazer. Had alot of backfires before I did this. Non since but it never hurt anything just keep eye on header and if 14,15 the stock can which is known to crack open. First sign is a rattle and the insulation being blown out of shield covering it.
Sent from my Galaxy S7
No I cheated and just used the pod 300 to richen the mid range. 6% is what I show. But I also changed mapping previously. I need to get it all in map. Is just so easy on Pod though.How did you correct it? By adding a little bit of fuel at 0 and 2% of throttle between 1500 and 3000 rpm?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I had back firing last year with my straightline header gasket until I replaced it this year with a new stock gasket. You could see where it was leaking. Small leak will cause the back firing!
