Backfire when shutting the RX1 down
Hot exhaust, unburned fuel vapors pumping out the exhaust valve when the spark is killed, POP!
Pull the plugs and check the color of them, post a picture if you can. It sounds like you may be running a little rich.
It is loading up when when I am riding at 1/4 throttle and then cleans out when I run it hard. I will pull the carbs when I get time and see if a choke is sticking or a float is sticking.
