allyammies
Do the ball joints have to be pressed out of the a arms or can you wack them out.
stingray719
allyammies said:Do the ball joints have to be pressed out of the a arms or can you wack them out.
When I did ours I whacked them out, wasn't bad popped right off.
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
You mean out of the spindles?
allyammies
Gonna repaint them out of the a arms.
I dont believe they are removable. When they wear you need a new a-arm.
Pics?
allyammies
Ok thanks guess they will have to tape them when powder coating.
Powder coating typically involves baking at a very high temperature so anything rubber, plastic, etc will melt and any grease or lube will also likely come out and ruin the job or the ball joint.
I say this as a man that has never seen the actual part in person, but I do believe this to be accurate.
The joints likely press in, but then there should also be a retaining ring to lock in place hence the request for a pic. You may well be able to remove them.
The Joints are molded into the a-arms. Not replaceable.
scott32
- Jan 12, 2009
There you go...wacking your balls for nothing!!
tator
why would you spend the money to powder coat them? i painted mine and then cleared with emron clear and have 1800 miles through cornstalks weeds and brush and still look like new. when i scuffed the black coating i didnt feel it was really that tough. just my .02
