Balljoint Mod
I meesed and it i read ski stance 42.82, spindal at 3 deg inwords, and lower a-arm was push forword by 1/20". Now remeber its not as good as the ball joint mod but I cant run with ball joind mods but can run with the shims.
If those shims go in A-arm at frame mount then its a caster change which is being done.Balljoint mod adjusts camber.These shims might help if done to A-arm.I may need to try playing with caster also.Maybe make whole new bushings to make some big changes to see if going in right direction.Thanks Marpolsdorfer
ooops forgot about that. Yea it adjust the caster but will mess with the camber to but not by much. This being becaues when you bolt sothing together the goes in a statinary spot; move it fowrod or backword slightly, it will either pull or push out. This instead of pulling the top of spindal in, it pushed the bottom of the spindal out.
