yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Going to make a template to stud machine and looking for a good pattern!
Sled will be tuned around 260hp
100% trail rider 1 1/4 track
Thinking of:
Studs 1.50 mega bites or 1.54 gold diggers
3 per row (a double and single on each row)
8 rows then repeat template
Any advice or suggestions from you guys would be greatly appreciated
Thinking of:
RAMSOMAIR
snowdust
Here is what I did. I bought the template from CBPerformance and then did the layout you see in the Google doc. Works well for me. https://docs.google.com/spreadsheets/d/1YAJ5fWfz2BC5UzNkJI7E5eiXilIqmvHGaf-NMOXdwNo/edit?usp=sharing
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Would have a picture by chance??Here is what I did. I bought the template from CBPerformance and then did the layout you see in the Google doc. Works well for me. https://docs.google.com/spreadsheets/d/1YAJ5fWfz2BC5UzNkJI7E5eiXilIqmvHGaf-NMOXdwNo/edit?usp=sharing
snowdust
krm
- Apr 22, 2016
- ny
I run 1.45" studs 2 doubles then 2 singles and so on .With a TD PT .Balance it out or you"ll be one of the guys wondering why you have a vibration
RAMSOMAIR
121"/136"/137" always full double backers and no vibration!
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
I run woodys pattern 4-2-4-2-4-2 great hookup.
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
I ran a 4 (2-double backers) 3 (singles) 3(singles) pattern for a total of 160. Just use the Woody's 137 template (286 T- I believe) that has doubles and singles and create as many scratch lines as possible.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
the 2/4/2 pattern works really well....
1.450s ....I don't like any taller, you will bend them.
Dan
Stud Boy Pattern: 2563-00 Template
9/16" penetration with Woodys 1.450'' on a 1.25'' Camso rip2.
Dan
RAMSOMAIR
Not understanding the single backers with the double backers. The whole reason for double backers is to gain greater support and lessen the tendency for tear outs. The mix of both is only accomplishing half of what we are trying to achieve here! So now half the studs installed are still vulnerable to this effect, hmmmm?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
2/4/2 is a long proven snowcross pattern.
I have run singles my entire life before this....and never had a pull out. Nothing wrong with singles at all. Many guys run all singles and never have issues. I only tried this snowcross pattern as it is so well documented to hook well. And I do like it.
Dan
Dan
ApexXTX/Viper
- May 5, 2014
Not understanding the single backers with the double backers. The whole reason for double backers is to gain greater support and lessen the tendency for tear outs. The mix of both is only accomplishing half of what we are trying to achieve here! So now half the studs installed are still vulnerable to this effect, hmmmm?[/QUOTE
When I mentioned the pattern I ran ( 2 double backers, 3 singles, 3 singles) to Larry Tiede from Woody's he just winked and nodded in agreement. Adding 16 studs and double backers to the proven 144 (3,3,3) both reduce the likelihood of stud pull out.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Thanks i just ordered this template (286t)I ran a 4 (2-double backers) 3 (singles) 3(singles) pattern for a total of 160. Just use the Woody's 137 template (286 T- I believe) that has doubles and singles and create as many scratch lines as possible.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Thanks for the suggestion I will stick with 1.450 stud length as you recommendedthe 2/4/2 pattern works really well....
Dan
I went with the Woodies template since i could not find the studboy template you suggested in Canada and to ship from the US was crazy
